Remote Control Problem
  • halim2731
    • 9
    Hi guys, I m using DM500s, with Gemini Image, I had a problem recently with my remote control, the issue is the command in the dreambox button do not match as it is. For example when I press the button Help it will exit...and the Vol- and Vol+ button does not function. It was working well before this. I had misdone something on the box which I had forgotten what I did. Pl help on this.
  • opsmonkey
    • 5379
    sounds like you need a new remote.. cant think of anything else which would make this happen..
    Maybe try a re-flash
    • westkill
      • 2378
      i had some thing like this using gemini no bomb image i did something
      the remote functions were all over the place
      i think i loaded some settings and it went mental
      think i had to reflash it in the end
      • waj_uk
        • 175
        I'm only commenting as it may help somebody else..i had this problem yesterday and sorted by going into blue panel then setup and changing the 70xx Remote Control option..
        it worked fine after that i wouldnt suggest flashing etc till you've this and a few other options
