SOLUTION PROBLEM DM500S
  • fort
    • 8
    HI ALL MY FRIENS
    i 'm new in this forum and i need help please
    i'had flashed my dream 500S with GEMINI 4.31 and when i readed that there is a problem with this image i tried to flash a nother image with dreamup
    i do it but the image still the same for GEMINI 4.31
    HERE MY LAST FLASH
    19:59:41 OK, flash erased
    20:00:09 Found no valid jffs2 in image, flash-erase not supported
    20:00:09 Uploading file to box...
    20:13:42 calculating CRC32 on STB...
    20:13:43 erasing flash...
    20:14:22 box is flashing from its memory...
    20:14:58 calculating CRC32 on STB's flash...
    20:15:07 OK, flash-copy succeeded
    20:16:49 Found no valid jffs2 in image, flash-erase not supported
    20:16:49 Uploading file to box...
    20:30:32 calculating CRC32 on STB...
    20:30:33 erasing flash...
    20:31:12 box is flashing from its memory...
    20:31:40 calculating CRC32 on STB's flash...
    20:31:49 OK, flash-copy succeeded
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Download the official firmware from the dream multimedia website and flash that.
    http://www.dream-multimedia-tv.de/english/downloads.php
    • edisitaru
      Download the Nabilo Maxvar v0.8 firmware from the Nabilosat website and flash that.
      • maria06
        bonjour j'ai acheter un dm 500s je l'ai flasher avec image gemini 4.70 var max apr?s 3 jour un signale clignante sur l'?cran clone,je l'ai ?teint et apr?s led noir et bloquer a jamais quoi-je dois faire aider moi S V P voila mon gmail
        [email protected]
        [email protected]
        • maria06
          bonjour j'ai acheter un dm 500s je l'ai flasher avec image gemini 4.70 var max apr?s 3 jour un signale clignante sur l'?cran clone,je l'ai ?teint et apr?s led noir et bloquer a jamais jai essayer de flasherai avec dreamup et flashwizar et dcc pas de connections quoi-je dois faire aider moi S V P voila mon gmail
          [email protected]
          [email protected]
          • Muzzy25
            • 68
            [email protected]
            [email protected]
            sounds like clone bomb destroyed your box so you need to jtag your box there is a guide how to do it at fallowing link
            it is not easy mind also if you manage to jtag it do not use Gemini image use bh or pli jade ok 
            • maria06
              bonjour Muzzy25
              je l'ai pris chez le r?parateur il n'a pas de jtag a souder donc un flash certainement merci
              • kiorismail
                • Feb 2013
                merc i tooooooooooooo
                • PaphosAL
                  Old Git
                  • 1064
                  I honestly cannot believe that total noobs are meddling in such dark arts like this... Why not stick to well-known clone-friendly images like OpenPLi or Commando 14.7?
                  Yours faithfully,
                  Baffled and bewildered
                  Somewhere north of London
                  UK
