WHY AM I UNABLE TO GET THESE CHANNELS
  • dagenham67
    • Mar 2009
    • 32
    I have a dm500s and subscribe to a card share package which is via fixed dish (communal sky dish).I get most sky channels but if I take my box a few hundred yards up the road to my m8s house I get more channels.The channels I get there but cant get via my own house include Sentanta Ireland Sky premiere and premiere plus 1 At the races ESPN Classic are the main ones.Any advice/help would be greatly appreciated.
  • tvadict
    • 363
    which box are you using? you need to do a manual scan. go to LyngSat - Lyngemark Satellite and check the transponders for channels you want
    • dagenham67
      • Mar 2009
      • 32
      Thanks m8 for your reply I am using a clone dm500s sorry to be so stupid but where do I look on the link for the necessary info ps have tried automatic rescan several times.
      • dagenham67
        • Mar 2009
        • 32
        tried manual scan frequency 11604 for sky premiere and premiere +1.Nothing found after scanning.
        • socktug
          • Jun 2009
          • 38
          It could be an alignment issue with the communal dish at your place. If your box is getting more chanels at your mates, then you know the box is fine and all the channels are scanned in. If you get a chance and know your neighbours, ask then if they get the mising channels on their setup.
          • dagenham67
            • Mar 2009
            • 32
            many thanks thought perhaps stupidly that as fixed dish you got all channels or none must be an alignment issue then.
            • socktug
              • Jun 2009
              • 38
              You should get all the Sky channels on a fixed dish as they are all broadcast from 28.2e, but I'm thinking that maybe the communal dish may not be aligned spot on.
              If your box is a clone for example, then the tuner may not be the best, and therefore the weaker signal would cause the channels to be 'lost' on your setup at home.
              It's just a thought though! It may be worthwhile to see if your mates box has the same issues on your communal dish.
              • dagenham67
                • Mar 2009
                • 32
                have tried 3 other boxes from my feed same problem but get all channels at my m8s
                • .: JaCkPoT :.
                  Retired Sat TV Addict
                  • 5607
                  Its definately a problem with your feed from the communal dish.
                  ___________________
                  In the good old days, I had
                  DM800s HD
                  Openbox S10
                  TM500
                  DM500s
                  90cm FortecStar dish
                  Maxx 110cm Dish
                  Technomate 2300 Motors
                  • socktug
                    • Jun 2009
                    • 38
                    I'm near certain it's a dish/coax issue then. Your best bet would be to find out who looks after that side of things and get them out t have a look at the alignment, and coax going to the tv point in your wall.
                    • dagenham67
                      • Mar 2009
                      • 32
                      many thanks all dont think I can get any one to look at it as dont have sky sub so would incur costs and have to explain what channels are missing
                      • ss0000
                        • Mar 2009
                        • 151
                        Maybe you can make a backup services file of your mates box and ftp the file to your box and see if the missing channels work as they will be on your box after. You can check the signal strength this way, might be worth a try
                        • .: JaCkPoT :.
                          • 5607
                          No its simple. the missing channels are on weaker transponders. That explains it all.
                          ___________________
                          DM800s HD
                          Openbox S10
                          TM500
                          DM500s
                          Maxx 110cm Dish
