dreambox 500s r2332 help
  • seangraves
    • Sep 2012
    • 275
    hi there im trying to flash the dreambox with image as box is just not booting up ,,,,ive downloadede dreamup ...but when i try to connect the port ie com port 1 is not showing its com port 6 ,,comport 7 etc up to com port 12 ,,,how do i solve this and get the box to connect to the dreamup ,,,,,ive tried different dream ups and there all starting at com port 6 etc idiots guide please
  • digicon
    • 8261
    Does it actually work on Com Port 6,7,8 etc.. as it will not always be on Com Port1.
    Com Port = Communications Port there are several different types on Motherboards so each could already be assigned by the operating system, When you plug in an RS232 lead then the next available port maybe either 6,7,8 etc...
    • seangraves
      • Sep 2012
      • 275
      no it doesnt work on any off the com ports thats showing the r3232 lead works fine as ive just flashed a skybox f3 which was dead early today and on the eprom firmware that came up with com port 1 ...i use to i flashed a dreambox about two m onths ago and that worked ok but now cant seem to get it to work on the dreambox ....ive been into settings on the computer the com port one is showing that its working ok .....
      • psats
        • 823
        use earlier version of dreamup {1321}
        • digicon
          • 8261
          I have always used this version on DM's and has worked every single time: http://www.digital-kaos.co.uk/forums...o=file&id=1861
          • edevs
            • Aug 2011
            • 55
            keep getting invaild image use version above of dreamup?
            • edevs
              • Aug 2011
              • 55
              Found no valid jffs2 in image, flash-erase not supported
              • psats
                • 823
                just select flash.
