dm500 flashing problems
  • dalpas
    • Aug 2009
    • 21
    Hi! guys,
    i am still having problems flashing, i am using universal dreamup, everything is ok till it gets to flashing to memory, it seems to freeze for a couple of mins, nothing moves along the progress status bar, then the bar is full & it comes up with the box, box flashed successfully, when i go to plug it in to the tv, it is still frozen solid with a solid green light that won't switch off,
    anybody out their that as a answer to this one,
    thanks,
    dalpas
  • firestorm
    • 1550
    have you rebooted the box by removing the power plug if so try loading it back with a diffrent image or even the orignal image see if that works
    • oldeno
      • Aug 2009
      • 274
      Try again, flashing erase twice.
      It might work.
      • .: JaCkPoT :.
        Retired Sat TV Addict
        • Aug 2008
        • 5607
        Flash a default image then boot the box without the network cable In. If it boots then flash your desired image and all should work again.
        ___________________
        In the good old days, I had
        DM800s HD
        Openbox S10
        TM500
        DM500s
        90cm FortecStar dish
        Maxx 110cm Dish
        Technomate 2300 Motors
        • dalpas
          • Aug 2009
          • 21
          Hi mate, do you know i their is a erase flash download on the dowload section, i looked but could'nt find?,
          cheers,
          dalpas
          • Curious123
            • 2591
            cheers,
            dalpas
            Try post #15;
