dremabox500s issues :(
  • Dreamboxnewbie
    • 6
    just got a dreambox500s and the green light is permanantly on
    my supplier told me to reflash the box whihc i have never done
    2 questions
    i have read a few threds and lookin to use dreamup but which image is the best one to use to flash is it the gemini one ?
    your help is much appreciated
    cheers
    s
  • dctyper
    • 2539
    Hi mate, welcome. use the dk image, very stable and user friendly Digital Kaos - Downloads - Digital Kaos v1.1 Image for Dm500 C/S/T
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
    • mm009b
      • 221
      green light
      green light should be on try press ok then pick sat
      • opsmonkey
        • 5379
        He needs an image mate first, looks like his box was supplied without one..
        • Dreamboxnewbie
          • 6
          hi all
          thanks for the help much appreciated
          i managed to flash my DM box with a Gemini_420_DM500.img
          rebooted and the green light still stays on - I cant even get the box to go to standby mode.
          when i press the standby button the green light stays on
          is this box useless then ?
          thks for you help so far
          • .: JaCkPoT :.
            Retired Sat TV Addict
            • Aug 2008
            • 5607
            Flash on the digital kaos image as advised.
            ___________________
            In the good old days, I had
            DM800s HD
            Openbox S10
            TM500
            DM500s
            90cm FortecStar dish
            Maxx 110cm Dish
            Technomate 2300 Motors
            • Dreamboxnewbie
              • 6
              hi
              flashed on the DK image as suggested green light still stuc on and does not go into standby
              • westkill
                • 2378
                Originally posted by Dreamboxnewbie
                hi
                you will have flash the image again with dreamup
                • Dreamboxnewbie
                  • 6
                  do i need to do the flash twice ?
                  • westkill
                    • 2378
                    before you try and reflash again
                    after you flashed dk image did you unplug the power and leave for 30 seconds and power up again
                    • Dreamboxnewbie
                      • 6
                      yes - but green light still on and standby button does not do anything
                      • Dreamboxnewbie
                        • 6
                        silly question but when you plug the power in is the green light meant to be on straight away ?
                        • citronel
                          • 127
                          you can try with another power supply:
                          12Vcc at min 3 amp.
                          I already changed the power supply on two DM 500s, this original power supply are know for low quality.
                          • mm009b
                            • 221
                            ok mate start again unplug box
                            start dream up with null modem cable pluged in press connect then switch box on and make sure it sais succesfully updated try that mate and let us know hope this helps what image have you tried i find pli images for 500 or dk images best
