My name is Dunner I have two DN500s one works perfectly the other when scanning wont lock on some transponders, I have tries several different images no change, the connection lead from the one that works properly no change when I bought the second box a clone I also bought a new tuner for the original box (not a clone) and had it fitted but it is still the very same when I scan I will get a load of BBC1 channels from different areas but not London nor will I get BBC2, BBC3, BBC4 or Film4 it does scan on both H & V and this is while using the same Dish, LNB, Cables and telly one box works properly the other does not pick up all the channels but the channels it does receive are picture perfect. I really need some help with this as I have spent so much time on it many thanks > Dunner.
DM500s will not lock on some transponders
hiMy name is Dunner I have two DN500s one works perfectly the other when scanning wont lock on some transponders, I have tries several different images no change, the connection lead from the one that works properly no change when I bought the second box a clone I also bought a new tuner for the original box (not a clone) and had it fitted but it is still the very same when I scan I will get a load of BBC1 channels from different areas but not London nor will I get BBC2, BBC3, BBC4 or Film4 it does scan on both H & V and this is while using the same Dish, LNB, Cables and telly one box works properly the other does not pick up all the channels but the channels it does receive are picture perfect. I really need some help with this as I have spent so much time on it many thanks > Dunner.
usually problem is some dreambox clone turner quality not good ,so can not scan some transponders,Comment
I assume that you have already done a full back up of the good box and transferred it to the problem dreambox?Comment
you need to replace mosfet Q72, IT`S A SMD component.
Howto: Repair faulty Mosfet Q72 in DM500
Dreambox LNB fix - Austech
good luck.
