DM500s boot problem
  • Trommy
    • 8
    DM500s boot problem
    Just flashed the box from `4.6 No Bomb` to `Darkstar 2`. Did the flash manually (I always do) from temp/ rename root.cramfs etc....but on powering up I get the Darkstar splash screen for 1 second then blank screen for 2. Repeats ad infinitum.
    FLashed without error but now won`t boot. I can ftp from DCC but not browser.
    Is there a fix I could apply over the LAN, or am I looking at Dreamup with Null Modem ?
    Thanks for any help,
    Trommy.
  • westkill
    • 2378
    if pulling the power for a few minutes
    dosent work looks like use dreamup m8
    • Manic01
      • 5117
      Yep def need dreamup.
      • Trommy
        • 8
        Bugger!....I have no serial port so I`ll try the USB to Serial adapter route.
        Thanks for the info.
        • joloughlin
          • 5
          Let us know how the USB->serial adaptor worked, I have the same problem and my 500s is arriving next week !!
          • Trommy
            • 8
            Will do, joloughlin.
            Incidentally, I thought that as I still had a good LAN connection to the box (but no boot), why couldn`t I just flash another image over with FlashWizard.
            Nothing to lose, so I flashed and everythihng is back to normal.
            So if others have a no-boot situation, but can still talk to the box over the LAN, well worth a go. Saves messing with Dreamup on puters without a serial port.
            I will test the USB-Serial method though.
            • rooney123
              • 11
              Hi lads..Can anyone help me..I got dm500s i fashed a gemmi image on it and when i hooked it up green light stays on and nothing on screen..I can flash using dream up with no problems i have tried erase flash and put another image on but still same problem,,Any help would be great thanks
              • Trommy
                • 8
                Hi, Rooney123,
                I`m new to this myself, but I`ll try to help.
                It sounds like you have a flashing problem. Which image did you originally flash it with, was it a `safe` image?
                Can you see the box through LAN connection ?
                If you can get a LAN connection you might want to try using DCC to FTP the image into the /temp directory, then manually install from the remote.
                Alternatively, use FlashWizard and go directly with the image.
                Are you using a known good null modem cable ?
                • rooney123
                  • 11
                  Hi, Rooney123,
                  Hi tommy thanks for the reply..I put a gemmi 420 on it i think that might have damaged it..I am using a nul cable and can flash with no problems but it wont rebot for me..
                  • Trommy
                    • 8
                    rooney123,
                    These problems usually caused by :-
                    (1) Bad Null cable.........change it for a known good one.
                    (2) Bad image..........download an official image
                    That gemini image does not contain the `bomb` so you should be OK. Try Jade3 or Darkstar2 from their sites.
                    If you have a cross-over Lan cable, you could try to connect that way. Did you setup Network on the box before it failed to boot?
                    • Trommy
                      • 8
                      jo,
                      Just flashed Jade3 image over using USB>Serial adapter.
                      I`m under Win7 and all OK.
                      Installed driver (had to use Vista), connect unpowered box, COM port recognised and connected to box.flash process started, 12 minutes later all OK.
                      I`m still at a loss as to why flashing over LAN (root.cramfs) is hit and miss.
