tps-how to open
  • kobkobk
    • 6
    tps-how to open
    can i open tps with db500s?
  • Curious123
    • 2591
    You need to load a cam like mgcamd 1.30 or CCcam 2.0.9 and you also need a key bundle such as the Satan keybundle.
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      I thought that TPS was still auto updating?
      Will need to have a play sometime this week .
      • chandra66
        • 22
        hi Devilfish
        will any CCcam (or EMUs in common) can go with DK image or do we have to spcifically go thru 'server K add on option ' from add on manager?
        CCcam's are found 'by googling" are they compiteable with dk image?
        this is because ,im facing problem (getting http error while downloading CCccam)
        thanks,
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          Yes all cams are compatible with the DK image.
          What you trying to download specifically? I'll check it out.
          You can do a manual install if you have the tar file in the /tmp folder too.
          • chandra66
            • 22
            Hi Devilfish,
            Great to receive your reply and thanks a lot; i have been in this forum since just begining of this month, but read quite your posts to walk thru the basics of dreambox.
            First of all thanks &apprecite the good work !! since yesterday i have been trying to d/l emu's from dk server ( i'm in middle east)
            is it possible that you can send me a download link (may be RS or so) for following for my dk1
            CCcam v2.08 (or the version successfully used with dk1)
            config for CCcam
            i need help to get the letaest key bundly to ftp to my folder.
            what is best way to update the keys ?is it using Haksat plug in loaded ?
            i have hotbird &Nilesat tuned on my 500s connected to LAN with ADSL.
            sorry if i put many things together ...kindly help.
            what packages in above 2 sats can be possibly open.
            thanks in advance
            <--chandra66 added 9 Minutes and 0 Seconds later...-->
            hi,
            my question was whether the EMU's are image specific programs?
            i mean a CCcam used for PLi image (e.g) can go with DK 1?
            • C64
              • 2394
              Some image creators have compiled special image specific versions of EMU's mate, generic EMUs will install onto any image as long as you put the files into the correct folders.
              • rrotan
                • 20
                tps isn't AU with CCcam or mgcamd anymore . you can decode it using a software called SBCL installed on your PC .
