Hi peeps
I must admit I read something in a forum and I didn't know that motors worked ths way if it's true that is !
If I set up my dm600 motor position settings for example as follows
Motor position 1 = 13 degrees east
Motor position 2 = 16 degrees east
Motor position 3 = 19.2 degrees east
Motor position 4 = 28.2 degrees east
If I then plugged my DM800 into the same motor all I would have to do is go into the tuner settings and input my tuner settings so position 1 would = 13 degree east, position 2 would = 16 degrees etc etc and I would be up and running.
I thought motor positions were saved into the receiver in the rotor table (dreambox anyway) and that the motor was nothing more than a moving arm and they don't have any memory. Or am I completely wrong ?
Could what I mention above actually work ? I must admit I having nightmare problems with setting my DM800 up and I am just having trouble coming from my relatively simple DM600 to my completely infuriating DM800. Both of which are original boxes not clones.
Any explanation would be gratefully recieved !
Many Thanks
)Could what I mention above actually work ? I must admit I having nightmare problems with setting my DM800 up and I am just having trouble coming from my relatively simple DM600 to my completely infuriating DM800. Both of which are original boxes not clones.
)Many Thanks
if 1.2 add your long lat as firestorm says
