Newbie 500S - Where do I get?
  • Asanee
    Hi,
    Where can I download the latest Gemini image and Flashwizard Pro?
    I think I had bad image, all black now
    Thanks in advance.
  • opsmonkey
    • 5379
    if you have a new d500s then it will be a clone so dont use any other gemini image than 4.2.. Gemini 4.2 for D500 is in the download area of our site
    • dank76
      • 745
      what programs do u need to get your dreambox 500s up and running for the start ?
      • opsmonkey
        • 5379
        My personal choice is..
        DreamUp (for flashing images, need to use a null modem cable to connect D500 to PC)
        Gemini 4.2 for D500
        Dreambox Control Centre (for FTPing files over)
        Then you can download your EMU's from the Gemini server via your remote
        • dank76
          • 745
          Gemini 4.2 for D500
          does it need to be linked to the internet to watch ?
          • Asanee
            .FW2 File
            But if someone sent me .FW2 file, then I will need Flashwizard Pro? Will I still need the Gemini 4.2?
            • opsmonkey
              • 5379
              a .FW2 is a Framework II file
              Your dreambox 500 needs a .img file like Gemini
              You need to use a program called DreamUp to flash the image file
              • dank76
                • 745
                do i connect dreambox 500s to my white vm box on the wall like my eurovox or do i need a modem and a ethernet cable ?
                • opsmonkey
                  • 5379
                  you need to connect the Dreambox to your router via ethernet cable
                  • Curious123
                    • 2591
                    I can't understand why you would even ask about connecting your dm500s to the VM white box when you know full well that VM have nothing to do with satellite.
                    • dank76
                      • 745
                      sorry but i have vm tv and vm internet but downstairs there is a white box on the wall which vm tv comes from . my modem is upstairs for internet so do i have to get a new modem for downstairs when i get a dreambox
                      • opsmonkey
                        • 5379
                        you need a router..
                        it sounds like you just have the modem.. to use a dreambox you need to have a router attached to your VM modem.. the Dreambox connects to the router via an ethernet cable..
                        A Dreambox requires a lot more knowledge than the cable boxes like the starview / eurovox
                        To get the best out of it you will need to be able to do the following:
                        Make your VM IP address stactic via aDynDNS address
                        Configure and port forward your router to your DynDNS address
                        Be happy setting up a LAN for your Dreambox to run off
                        Be able to input linux code into configuration files then use a FTP program to transfer them to your box
                        Dreamboxes aren't plug and play machines like the cable boxes
                        • whyohwai
                          • 5
                          should i go for the gemini 4.2 or 4.6 then?
                          • Superman
                            • 520
                            Go for naiblosat mate, trust me.
                            Super
                            • .: JaCkPoT :.
                              Retired Sat TV Addict
                              • 5611
                              Yip. Nabilosat all day long.
                              You dont need a router, just spend a few quid to get a network switch. alot cheaper alternative.
                              ___________________
                              In the good old days, I had
                              DM800s HD
                              Openbox S10
                              TM500
                              DM500s
                              90cm FortecStar dish
                              Maxx 110cm Dish
                              Technomate 2300 Motors
