Got my Dreambox 500S
  • kopkidda
    • 122
    Going to try and set it up later, have sky dish pre installed, so im presuming there is an image on this Dreambox already, how do I check that this is the case and if so how do I scan in the free channels from the sky dish?Thanks
  • Superman
    • 520
    Hi Mate,
    The best thing to do would just to install a image, to see if a image is on, just tell us what you see when you start the box up, all images with show a picture with image name on ie Gemini, niablosat ect.ect
    To scan the channels it will ask you to do this on first set-up, it says "No Disq" which you need then it will offer a automatic scan, however i would scan, then try loading a channel list to get some order and save you time..
    many thanks
    • kopkidda
      • 122
      Originally posted by Superman
      Hi Mate,
      many thanks
      Thanks for your reply, so basically once I have it connected and turned on it will ask me to scan,which I accept and then I will have the channels?
      • Superman
        • 520
        Yes, but before you scan install your image, as a image installtion will remove your scanned channels.
        • kopkidda
          • 122
          Why would I install an image when there is one on it, think its a Gemini 4.2 for clones.
          • Superman
            • 520
            a lot of boxes dont come with a image pre-installed on them just standard enigma, so make sure a image is installed first. Also you may want to update your image to a newer one, which will be better i.e Gemini 4.6 NON BOMB.
            • kopkidda
              • 122
              Ok,whats the advantages of downloading this new 4.6 image over th 4.2?Features?
              And whats the best image out there at the moment for a cloned 500s?
              • Superman
                • 520
                As the images are more recent they are more stable and usually faster, my personal Favorite is the NiabloSat 0.8V MaxVar as i find this very fast and quick, also easy to use.
                • kopkidda
                  • 122
                  And is this ok for clones?Is it easy to set up etc?Ive sent you a pm
                  • Superman
                    • 520
                    yeh fine on clones, really easy set up and nice user interface, i personally install this image on all reciever i sell.
                    • whyohwai
                      • 5
                      i m on the same boat as kopkidda! nice one superman!
