drembox 500s
  • joeman
    • 88
    drembox 500s
    hi guys i have been on here with same problem some time ago my old dreambox 500s clone cant put image on it tried dream up it says box alive and speaking but when you flash it at the end get error any new software out now to fix this problem cheers
  • kevin64
    • 170
    download and try a diffance image
    • joeman
      • 88
      can you factory reset dm 500s
      tried lots of images is there a factory reset for thes boxes or format or drivers some think like that want to give this box to friend he just starting out would like to fix if possible cheers if anyone can help
      • kevin64
        • 170
        have you got a 500 plus or 500 because they diffance files have a read of this post
        this is a quote from anther post are you shore you useing the right images also have you tryed a diffance dreamup file
        has anyone tried this image with the Dreambox 500 plus? Just to make sure it`s compatible before trying..
        dm500plus uses openembedded images do they not?.. i.e .nfi images,
        thats standard dm500 image by looks of it mate __________________ so what 500 have you? also gemini images put a bomb in them to wreck your box if it was a clone go to you tube will show you how to jatag if its been bombed [ame="http://www.youtube.com/watch?v=SxQB1fRs1fc&feature=PlayList&p=601793F7D9F 64BD6&playnext=1&playnext_from=PL&index=29"]YouTube- Dreambox 500 Jtag Tutorial[/ame]
        • joeman
          • 88
          dreamox 500 s not plus m8
          • kevin64
            • 170
            try this one try this one and this dream up its a really old offical image from 2006 see if this works
            • firestorm
              • 1550
              are you using a usb to rs232 adaptor if so try a old pc with a rs232 port(old printer port) on it
              • joeman
                • 88
                got it going
                hi guys thanks kevin got it working perfect thanks to everyone my m8 will over the moon now cheers and thanks again this is a great site
                • kevin64
                  • 170
                  did you use that image joe
                  • kevin64
                    • 170
                    most old dreambox need a offical image first then you can flash one over the top of it now with flash wiz pro should take most images one you have built up a image back it up with flash wiz pro save you alot of work again
                    • joeman
                      • 88
                      yes kevin i used that image and put another over it worked like a charm cheers m8
                      • kevin64
                        • 170
                        if you loaded a blank image send these setting over to it var tuxbox the image will then be set up for a motor with channel and sats install you will only need to add cams and refresh the scan http://www.digital-kaos.co.uk/forums...satellites.zip
                        • joeman
                          • 88
                          help
                          hi back again dreambox 500s gone down again was working fine last night today worked for a while then just box just freeze cant turn on or off can you put firmware on on them boxes or should i just dump it tried to flash it again but keep getting error lockbits
                          • Superman
                            • 520
                            Flash with Niablosat 0.8 Mate.
                            Best DM500s image.
                            Super
                            • joeman
                              • 88
                              can i download it from here cheers
