I have just bought dreambox600s pvr. Downloaded files from dreamweb site. They are in NFI format and I cannot open the files on my computer. Cannot open files it neess to know who created the. Thank you for any help.
NFI files
Tags: None
why do you need to open files the nfi is the image you use dreamup to flash image to your dreambox. -
You can use ethernet cable and telnet;
Slightly different to other dreamboxes. You can either use the Dreamup software (takes ages) or use the method below instead.
1. Boot the box, goto the communication menu and note the ip address.
2. Run DCC, connect to the dreambox. Once the network is connected ok, click on the the 'Telnet' option.
3. In the telnet window, type the following, pressing <return> at the end of each line.
mount /boot -o remount,rw
rm /boot/*
reboot
4. You should now get a message saying that the Dreambox is rebooting.
5. Wait a few seconds and then run Explorer (Firefox or whatever) and enter the ip address of the Dreambox in the address bar.
6. On the screen that appears, choose the 'Upgrade firmware' option, find the .nfi file and click the 'Flash' button.
7. Once the progress bar reaches 100%, reboot the box
DoneComment
crap
Hi,
Everything went ok until point 5. I can not reach the dreambox anymore on its IP address and when I ping it it is also timed out. On the dreambox itself I see "Dream Multimedia 192.1x8.x.x/flash/zImage.elf"
Can anybody help me to figure out what to do now?
ThanksComment
hello to everybody
i have dreambox dm800 hd i flash with a lot of flash file for dreambox dm800hd but in lcd is same logo DREAM MULTIMEDIA
WHEN I RESTART AFTER FLASH
some flash file who i use with DREAMUP V1.3.3.4:
BlackHole_Hyperspace_DM800_03.nfi
DreamEliteBH_DM800_133D-sim2-ramiMAHER.nfi
gemini2-470-dm800-201002090910.nfi
NabiloBlackHole_DM800_012.nfi
OoZooN-CVS-lean-dm800-20100925.nfi
sim201-bl76c-DreamEliteBH_DM800_133D_mfaraj.nfi
dreambox-image-dm800-20081217123407.nfi
experimental-dm800_20101013.nfi
LT-Sixth-dm800.nfi
OoZooN-CVS-full-dm800-20100925.nfi
release-dm800_2.8.4.nfi
and the end ......... nothing
some 1 know what to do ??????????
plsComment
Hi ,I've problems seeing NFI file with dreamup v1.2.2.0 also tried v1.3.3.0 I can load image but when I go to file where NFI image is stored its dose'nt appear, I can't alter setting in dropdown box to view other files after I select flash, is there another version of dreamup that I should be using or just what am I doing wrong ?? I'm running xp proComment
