got dm 600, plus 80cm dish. i want to card share but what do i need to download to the box and how? its probably a clone as it cost ?100
help!
Tags: None
Concentrate on just getting the FTA stuff and 1W Thor Digitv for now and look at cardshare later on when you have mastered your box. -
That will be your null modem m8
Is it the same as this Serial Null Modem Cable DB9F to DB9F RS232 1.5m on eBay (end time 12-Jan-10 18:56:52 GMT)
Well he said rs232 and not null modem cable so not sure what to believe.
Personally i would go with the telnet method below as it is much quicker than Dreamup;
1. Boot the box, goto the communication menu and note the ip address.
2. Run DCC, connect to the dreambox. Once the network is connected ok, click on the the 'Telnet' option.
3. In the telnet window, type the following, pressing <return> at the end of each line.
mount /boot -o remount,rw
rm /boot/*
reboot
4. You should now get a message saying that the Dreambox is rebooting.
5. Wait a few seconds and then run Explorer (Firefox or whatever) and enter the ip address of the Dreambox in the address bar.
6. On the screen that appears, choose the 'Upgrade firmware' option, find the .nfi file and click the 'Flash' button.
7. Once the progress bar reaches 100%, reboot the box
Done
My image of choice would be the Pli Jade 3.Comment
You say you have cardshare sorted but you don't even have an image on your box. There is a lot more to cardsharing then just getting a cline from some pay server as you will find out soon enough.Comment
its the same as that image yes. so i have my box do i attach it to my laptop using that cable? thanksComment
Not unless you got a usb on one end or a rs32 port on your lappy you wont be able to.
just need to know if i need to download anything to my laptop before i connect it to the dreambox?Comment
Follow post #4 you only need dreamup and your image
ok brilliant thanks, installed dreamup. any image suggestion for dreambox600? it cost ?100 so might be a clone?Comment
