Sky digital dish
  • khoda7
    • 179
    Sky digital dish
    Hello peeps
    Can i use my mini sky digital dish to connect to a dreambox 500s? Will i need to re align dis dish as it is small?
    Can i use the white card already inside my sky box on the dreambox?
    If i unsubscribe to sky will i be tracked down for using their card on the dreambox? The signal will be coming thru the dish right, dat cud be dangerous for me
    You can use a valid card in your box. If you stop your sub you wont get anything because sky is not hacked
    I think you need to do a lot of reading about the Dreambox and it's capabilities because you don't really understand it.
    • khoda7
      • 179
      i knw u cant watch ftv channels without sum sort of sub however if i unsub den i can use the method of cs right.
      all i need to knw is if i can use my sky dish and card to set up cs or is da sky dish too small
        Well no. Because if you cancel your sub then you've got nothing to share ?
        Besides, if you were looking down that route you would really need a motorised dish.
        • khoda7
          • 179
          wats da diff between a sky dish and a motorised dish?
            you can beat a sky dish in a race....sorry m8 could'nt resist
              A Sky dish is a mini dish fixed on Astra 28.2E. A motorised dish will turn and pick up different satellites. The bigger the dish the more Satellites you can pick up. A 1m dish is normally ample for the majority of people
              • khoda7
                • 179
                i only need sports channels like sky sp1,2,3 extra
                can i jus use my sky dish to pick up watever sat it can, i dnt require european channels for the dish to pick up other sat
                  Well short answer is yes.
                  • khoda7
                    • 179
                    so to sum it all up i can use my sky dish and card and unsub to sky
                    then i can buy a dreambox 500s and set up cardsharing by paying a payserver who is sub
                    • Superman
                      • 520
                      Yes you can,
                      but rememeber cardsharing isnt to be discussed her bro.
                      Super
                      • kopkidda
                        • 122
                        khoda7 sent you a PM
                        • tvadict
                          • 363
                          you wont need any card inside your box if you are thinking of paying someone.
                          Sky Mini dish is more than enough if you want just sky UK. You wont need to move the dish at all. Signal will be 90%+ all weather
                          • khoda7
                            • 179
                            is der anyway dat i mite be caught doin dis by the coppers
                            after all the signal will be coming frm a dish
                              Speak English only in the forums please
