hi guys can anyone help im new to the sat scene i have a dish with one lnb and currently have a dm600c using pli jade 3 image can i use this image with my sat card to get free to air channels etc thanks and how would i go about setting up thanks
dm600c change to 600s
the Pli image will work with both cable and sat, just set it to default settings.
your going to need a sat tuner to replace the cable tuner, its just a plug and play one so easy to do.
only problem is they are hard to get at the mo.... maybe China is the best option just now..
they cost about ?30
The dm600 is a linux pc and the last time you used it you had a cable tuner now if you take out the cable tuner and replace it with a sat tuner it will need to reconfigure the OS. I am no expert on linux and you could try it without re-imaging the dm600 but if it doesn't work then you are going to have to re-iamge the dm600 so you might as well save yourself some time and do it after changing the tuner so you have a clean build.Comment
