DM500 and motorised dish, no power?
  • tkm18
    • Aug 2009
    • 158
    Got a clone dm500, flashed with PLi image, thats fine.
    Hooked everything up and the receiver doesnt appear to be powering the dish, no light on, TM2300 Super.
    Ive read conflicting reports as to wether or not the receiver can actually power a motor.
    Any ideas?
    TIA.
  • jumpinjo
    • 869
    hi bud ive only recently put dish up with same motor as yourself and dm500s and not having any probs
    • tkm18
      • Aug 2009
      • 158
      Nice one, needed that info.
      You still got your site with KMS??
      • jumpinjo
        • 869
        hi bud, yup still there
        as i said ive only been up and running for over a week but same setup as yourself and only diff is clone freindly image from sunrise and motor works np,s at all, infact its all dandy and iam fair chuffed
        • tkm18
          • Aug 2009
          • 158
          What/where is the image you have?
          Pm me the link for the forum, will pop back on and see how folk are.
          Been awhile since i spoke to anyone from years back.
          • jumpinjo
            • 869
            i will pm link for his image as well and if stuck giz a shout as ive picked his brains and done his tits in till early hours getting it right
            • bugaloo41
              • 1598
              Have the same probs with a 500s and have tried pli and nabilosat images but motor just doesnt move. Pity as the picture quality is good when your on a sat LOL. I need to use a TM500 to drive the motor and swap boxes.
              Might be the dream itself but wonder if the sunrise image is freely available? If its a closed shop no problems respect that but if its available any chance of a heads up JJ?
              JJ by the way thanks for pm mate with the installers details - i will give the guy a call if i cant fix it myself.
              • Curious123
                • 2591
                Check your connections on the motor are watertight also check the PSU on the dm500 as some of the clone PSU have been known to be weak.
                • jumpinjo
                  • 869
                  pm sent boogy
                  • bugaloo41
                    • 1598
                    Curious not that mate as the other 2 boxes i have (not dm 500s mind) drive the motor fine. thanks anyway.
                    • psul
                      • 24
                      Believe this is a fairly common problem with the 500. Ive read of some having to upgrade psu to 2amp(?) to get motor power.If you google the problem I'm sure youll get the correct details.
                      • tkm18
                        • Aug 2009
                        • 158
                        Read that aswell, but ive spoke to 3 or 4 folk with the 500 and there motors works fine.
                        Its really doing my nut in.
                        • mdt
                          • 3034
                          dm500s motor problem
                          your not the only one m8, ive just tried with my motorised dish and it wont budge. been messing about for a couple of days and the box just wont play ball!, but when i plug it back in my 60cm fixed for freesat it works like a charm.
                          • firestorm
                            • 1550
                            the problem is some were in your setting i cant rember which setting as i have not had a dm500 for a long long time but when i first swapped over from a technomate to a dm500 i had to loop in from my technomate to move the dish
                            then i played around with the options on the setting and it worked perfect sorry for being vague but it was about 5 years ago
                            • tkm18
                              • Aug 2009
                              • 158
                              Ive spoke to the guy i got it from, he's willing to swap the motor if its deffo faulty, reckons any box should power it up.
                              Need to find a Sly box test it properly.
                              Im really confused by it, guys i know with the kit rave about it, motors work no problem, but searching is flinging up problems.
                              BTW, will it still send a signal to the 500 if theres no power to the motor?
