problem with dm500s philips tuner
  • fricker
    • 538
    hi. i have problem to flash boot to dm500s JS28F640 with philips tuner. this DM is new and i will chang MAC . i write MAC in bat file and start boot uploud and all is fine. problem is that after uploud tuner cant find satelites and have other problems. maybe this philips sw is for cable tuner ? i have flashed ALPS and all is fine . how to flash this philips tuner ?
  • jbvid
    • 261
    Hi
    If you have the option to do a Satellite scan you have the correct bootloader, but you mention you flashed Alps, this is wrong.
    If your dm has philips tuner jtag command line should have philips like this.
    "jtagdm500 -m dm500 -d philips" without quotes.
    jbvid
    • fricker
      • 538
      Originally posted by jbvid
      Hi
      jbvid
      i have flashed with this sw dm500s apls tuner and it works fine but problem is dm500s with philips tuner if i flash it i dont have satelite menu and other problems. i think this sw is for philips cable tuner not for satelite. i need 100% satelite philips sw . i have working tuner with philips maybe is some sw to read out boot from it ? and then dounloud ? i need to change mac on this tuners with philips chip.
      • jbvid
        • 261
        fricker
        I you are using the Dos software try downloading another Jtag set maybe from elsewhere and try again. As you say the version you have maybe for a Cable tuner.
        I did the opposite to you and had same problems, I loaded a Satellite philips version into my Cable philips dm500c and had no menu to scan for either Sat or Cable, but mine sorted now after finding a Cable file.
        jbvid
        • fricker
          • 538
          yes i use DOS sw. maybe you have this philips sat version that you have loudet to cable tuner ?
          • jbvid
            • 261
            Hi
            Yes, sure your welcome to try it.
            jbvid
            • hamzatuning
              • Nov 2011
              ihave the same problem iam not a pro
              • keanyal
                • Apr 2012
                i have the same problem too
                • diaa aaaaaa
                  • Apr 2012
                  ihave this proplem
                  ihave dm500s and i dont see
                  the option scan ch
                  • adaf
                    • Jan 2013
                    Hello there
                    Is there a way to tell which tuner i have in my DM500s clone?
                    There no "philips" or "alps" written anywhere
                    Thank you
                    • adaf
                      • Jan 2013
                      I have a couple more questions since i am a newbie
                      In case i flash with a jtag cable the dm with the wrong tuner file, for example "philips" instead of "alps". Will something really bad happen? Of course the tuner will not work but is it going to make a hardware damage to anything? If i reflash the dm with the correct tuner file later will everything be ok?
                      Thanks again
