Setting Up New 500s
  • branoox
    • Aug 2008
    • 10
    Setting Up New 500s
    Can Someone Guide Me To Instructions What To Do.
  • krazylegz
    • 2834
    what are you stuck on??
    more info required please m8
    PS3= krazylegz120282
    • branoox
      • Aug 2008
      • 10
      Setting Up New 500s
      Thanks For Replying. I Have Just Ordered One, And I Would Like Know If I Need To Load It With Any Software To Receive Gbox C***S*****G.Regards.
      • Curious123
        • 2591
        You will need to load an image if it does not come with one preloaded and yes you need to load it with the Gbox C***S*****G software.
        • branoox
          • Aug 2008
          • 10
          Setting Up New 500s
          Can I Use Kaos v1.0 I`ve Seen Advertised On The Forum
          • Curious123
            • 2591
            You can use any image as long as it is for Dm500, DK1 will do fine.
            • branoox
              • Aug 2008
              • 10
              Thank You, One Final Point, Is It Self Loading Or Do I Need A Loader
              <--branoox added 2 Minutes and 41 Seconds later...-->
              I Was Almost There And You Put Your Clothes Back On.
              • krazylegz
                • 2834
                you need to load any software onto a dreambox m8.
                you can use a program called dreamup and a serial cable (my preferred method)
                you can ftp it to the dreambox and use commands to flash it
                or you can use a program called flash wizard pro, which is the fastest way to flash when it works, but fails a lot of the time and you end up needing to use dreamup to recover it.
                as for image wise i prefer nabilosat0.8 maxvar (avaiable in the downloads), keep away from gemini images cos if your box is a clone gemini will kill it
                • branoox
                  • Aug 2008
                  • 10
                  Thanks M8, Waiting For My Box to Arrive So I Can Get Started. Hope You Win The Lottery Week After Me.
