dm500c minisatip & satpi
  • atari
    • Mar 2010
    trying to make dm500c work like satip, need help to compile minisatip or satpi for ppc
    root@ubuntu1404:/opt/dm500-satip/minisatip# ./configure --host=ppc --enable-enigma --disable-dvbca --disable-dvbcsa --disable-satipc
    checking for ppc-gcc... no
    checking for gcc... gcc
    checking whether the C compiler works... yes
    checking for C compiler default output file name... a.out
    checking for suffix of executables...
    checking whether we are cross compiling... no
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether gcc accepts -g... yes
    checking for gcc option to accept ISO C89... none needed
    checking for main in -lrt... yes
    checking how to run the C preprocessor... gcc -E
    checking for grep that handles long lines and -e... /bin/grep
    checking for egrep... /bin/grep -E
    checking for ANSI C header files... yes
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking arpa/inet.h usability... yes
    checking arpa/inet.h presence... yes
    checking for arpa/inet.h... yes
    checking fcntl.h usability... yes
    checking fcntl.h presence... yes
    checking for fcntl.h... yes
    checking netdb.h usability... yes
    checking netdb.h presence... yes
    checking for netdb.h... yes
    checking netinet/in.h usability... yes
    checking netinet/in.h presence... yes
    checking for netinet/in.h... yes
    checking for stdint.h... (cached) yes
    checking for stdlib.h... (cached) yes
    checking for string.h... (cached) yes
    checking sys/ioctl.h usability... yes
    checking sys/ioctl.h presence... yes
    checking for sys/ioctl.h... yes
    checking sys/socket.h usability... yes
    checking sys/socket.h presence... yes
    checking for sys/socket.h... yes
    checking sys/time.h usability... yes
    checking sys/time.h presence... yes
    checking for sys/time.h... yes
    checking syslog.h usability... yes
    checking syslog.h presence... yes
    checking for syslog.h... yes
    checking for unistd.h... (cached) yes
    checking for int16_t... yes
    checking for int64_t... yes
    checking for int8_t... yes
    checking for size_t... yes
    checking for uint16_t... yes
    checking for uint32_t... yes
    checking for uint64_t... yes
    checking for uint8_t... yes
    checking for GNU libc compatible malloc... yes
    checking for sys/param.h... yes
    checking for getpagesize... yes
    checking for working mmap... yes
    checking for bzero... yes
    checking for clock_gettime... yes
    checking for dup2... yes
    checking for gethostbyname... yes
    checking for gettimeofday... yes
    checking for inet_ntoa... yes
    checking for memset... yes
    checking for munmap... yes
    checking for socket... yes
    checking for strchr... yes
    checking for strerror... yes
    checking for strncasecmp... yes
    checking for strstr... yes
    configure: == Checking LINUX DVB ==
    checking linux/dvb/frontend.h usability... yes
    checking linux/dvb/frontend.h presence... yes
    checking for linux/dvb/frontend.h... yes
    configure: == Checking OpenSSL ==
    checking openssl/aes.h usability... yes
    checking openssl/aes.h presence... yes
    checking for openssl/aes.h... yes
    configure: == Checking Embedded ==
    checking for backtrace... yes
    configure: == Checking NETCVCLIENT ==
    checking netceiver.h usability... no
    checking netceiver.h presence... no
    checking for netceiver.h... no
    configure: creating ./config.status
    config.status: creating src/Makefile
    config.status: creating tests/Makefile
    config.status: creating Makefile
    minisatip configuration
    Linux DVB: enabled
    Common Interface (needs DVBEN50221): disabled
    OpenSSL (AES as part of DVBAPI): enabled
    Embedded system: disabled
    DVBCSA (needs libdvbcsa): disabled
    Netceiver support: disabled
    SatIP Client: disabled
    Static: disabled
    dvbapi: enabled
    axe: disabled
    enigma: enabled
    root@ubuntu1404:/opt/dm500-satip/minisatip# ./build.sh
    make -C src
    make[1]: Entering directory /opt/dm500-satip/minisatip/src' make[1]: Leaving directory /opt/dm500-satip/minisatip/src'
    make[1]: Entering directory /opt/dm500-satip/minisatip/src' gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c minisatip.c -o ../build/minisatip.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c socketworks.c -o ../build/socketworks.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c stream.c -o ../build/stream.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c adapter.c -o ../build/adapter.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c utils.c -o ../build/utils.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c aes.c -o ../build/aes.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c dvbapi.c -o ../build/dvbapi.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c pmt.c -o ../build/pmt.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c tables.c -o ../build/tables.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -c dvb.c -o ../build/dvb.o gcc -fPIC -Os -DVERSION="1.0.0-07cb6fc" -DDISABLE_DVBCSA -DDISABLE_DVBCA -DDISABLE_SATIPCLIENT -DDISABLE_NETCVCLIENT -DDISABLE_DDCI -DDISABLE_T2MI -DENIGMA -o ../minisatip ../build/minisatip.o ../build/socketworks.o ../build/stream.o ../build/adapter.o ../build/utils.o ../build/aes.o ../build/dvbapi.o ../build/pmt.o ../build/tables.o ../build/dvb.o -lpthread -lrt -lcrypto make[1]: Leaving directory /opt/dm500-satip/minisatip/src'
    /opt/dm500-satip/buildroot/output/host/usr/bin/powerpc-buildroot-linux-uclibc-strip: Unable to recognise the format of the input file `minisatip'
    build.sh:
    #!/bin/sh
    CC=powerpc-buildroot-linux-uclibc-gcc
    CFLAGS="-fPIC -Os" EMBEDDED=yes
    ENIGMA=yes DVBCSA=no DVBCA=no SATIPCLIENT=no make &&
    /opt/dm500-satip/buildroot/output/host/usr/bin/powerpc-buildroot-linux-uclibc-strip minisatip
