500S and Gemini
  • NineLives
    • 79
    500S and Gemini
    Does the Gem image still kill clones? Or has that been fixed now?
  • ^^MaXiMo II^^
    • 80
    why use gemini ????????
    here mate
    ::::>>Nabilosat<<::::
    BlackHole project
    • NineLives
      • 79
      Originally posted by ^^MaXiMo II^^
      Cheers for that but I still need to know if the Gem kills boxes or not?
      • portbhoy
        • 717
        Yes mate it will leave you unable to access the blue panel, there was a patch but I couldn't honestly tell you if it worked as I wasn't stupid enough to try. Best advice is the previous post
        • krazylegz
          • 2834
          why do people ask so much about gemini???
          they are personally my least favourite dreambox image, theres nothing special about them, even after what they done to peoples boxes people still want to use them......beyond me??
          you wont find a better looking image than a nabilosat and also has one of the best addon servers too
          PS3= krazylegz120282
          • durasoft
            • Aug 2008
            • 57
            Ive put Gemini 4.20 into what i think may be a clone and its working fine.
            Ive seen 2 boxes now that look identical to an original inside and outside the box, even info on the board but it killed them both.
            Be Warned mate
            I agree the nabilosat image is agood one for the DM500s.
            Regards T
            Humax FoxSat-HDR
            Great HD/SD Box with 500GB HardDrive
            Manhatton HH-120 42E-30W
            Triax 88cm 0.3db
            SKYBOX F3
            HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
            Intel Core i7 [email protected]
            MSI R7970 Twin Frozr Boost Edition
            • spectra
              • Aug 2008
              • 54
              Here's the problem with telling people not to use Gemini still!!!!!
              I have had gemini 3.6.0 and untill Friday since it came out 4.0.0 because thats what someone taught me to use when I wanted to learn C/S im sure my box is a clone as well fortunatly i never installed 4.2.0! I finally plucked up the courage this Friday to install different imagesand all have been a pain!
              Eagle v4 doesnt have inadyn installed you got to do it manual not got that knowledge Nabilsat V8 wouldn't install cam properly and the highly rated DarkstarII which has everything I need has decided not to recognize 28.2e / 1w or 4.8e from my saved bouquetts installed via dreamboxedit instead 28.2e it thinks is 28.4e and I have to do total transponder scan in order to get channels that I know if I revert back to Gemini will work perfectly but what do you do Bouquettes changing is a pain and what if I change image again and this time it dont recognize 28.4e and wants me to go back to 28.2e!!!
              Im seriously think of trying Gemini 4.4.0 or going back to 4.0.0 cos at the end of the day everything worked fine with them!!!
              Any thoughts?
              Dreambox 8000HD Fully Loaded
              • Curious123
                • 2591
                I really liked the look of Darkstar II but had the same problem as yourself. Until recently I have always been a fan of the Pli images but than my Digitv stopped working so I thought I would try Nabilo v8. This image worked really well even with all the card sharing although recently the plugin for checking the cardsharing has stopped working but I know the cardsharing is working so not too bothered really with the plugin.
                • spectra
                  • Aug 2008
                  • 54
                  Well that seems to have sorted my problem Nablio v8 doesnt disregard 28.2e channels and C/S all working fine thanks curious.
                  • zeroprobe
                    • Aug 2008
                    • 20
                    The patched one works fine. I've had it running for weeks on my clone.
                    • psats
                      • 823
                      were did you get this patched version from.?
                      • zeroprobe
                        • Aug 2008
                        • 20
                        Search for this
                        GP440_DM500_mv_xd_without_bomb
                        • psats
                          • 823
                          Search for this
                          thank you.......
                          • KaosBaby
                            • 5
                            Gemini image from 4.30 up might affect clone DM 500, use image 4,2. or less
                            • shadow28
                              Hi : Need advise
                              Hi all,
                              I would like some advise as I am getting two DM500s clone units, one will be running what ever image that it comes with (configured to connect to card server) while the second one is the test unit which I intend to try out new images.
                              I will be using the dreambox for Measat 3 91.5E, and they have recently changed to NDS Videoguard. A bit of search on the internet reveal that CCcam v2.09 works best.
                              My question is that which image (Gemini, Nabilo, etc ) works best with CCCam?
                              Also I have a valid subscription card and if I wish to share my card out from the first box to the 2nd box (solely for education purpose) any pointers of where I can find more info?
                              Many thanks :-) Hope to learn more and contribute back ...
