Bouquets - Sending to DB
  • ns77
    • Jun 2009
    • 35
    This is doin me head in,DBedit files to PC,move files around i.e sport,music,news etc,save file,send file back to DM600, (/var/tuxbox/config/enigma/) reboot DM600 & hey presto,nothing has changed...if i modify files on DB & send to PC it shows the changes,but if i modify on PC send back to DM nothing changes,also tried manually using FTP Cute...any ideas chaps
  • bugaloo41
    • 1598
    You could try dreamset - simple to use and should do the job perfectly well - available in downloads
    • ns77
      • Jun 2009
      • 35
      will give it a go,but still cant figure out why DB doesnt see modified channels,,,,,,,not giving in YET..
        As Bugaloo said m8, use Dreamset to arrange the order you want and ftp back to your box. Saves all the hassle
        • ns77
          • Jun 2009
          • 35
          tried dreamset just the same,could the dm600 be reading the wrong folder,is there a setting to tell it where the bouquets are,using darkstar2,cccam 2.13---- not a problem moving channels around on the DM600 then uploading its just when you move em around with dreamset ,save then send them back,go into bouquets and nothings changed....BTW dreamset smart piece of kit
          • father ted
            • Feb 2008
            • 1389
            quick one for i found if i use an older version of db edit it worsk with my 600 .the neweer versions says its sending them to the box but iw as the same as you nothing changed i use open dbedit 3.0.6 works all the time now
            • ns77
              • Jun 2009
              • 35
              cheers ted downloading as we speak so will give it a try,dont hold much hope,i think the dm600 isnt looking in var\tuxbox\config\enigma folder for the bouquets....
              • ns77
                • Jun 2009
                • 35
                WELL DONE Father,it works,whats that all about,tried 4 different programs & the oldest version works !!!! you just saved me going out to the garage & getting a huge hammer and smashing the S**t out of the DM600....cheers mate
