Dream clone 500s chinese to english
  • mickopla
    • 6
    Got a clone 500s but it has the Chinese version of Enigma pre loaded. How do i change the osd menu to English? Searched Google with no luck, Tia
  • westkill
    • 2378
    flash a newer image with dreamup plenty in the downloads section
    • mickopla
      • 6
      Actually managed to change the settings to english and its a gemini image. The problem i know get is when i try to download addons i get a 404 error. I can FTP to the box using DDC but can get online. I tried to manual install cccam and it says its installed but i cant see it in the addons or cam settings, just says Common Interface. Can anyone help??? Tia
      • opsmonkey
        • 5379
        do as said above.. take off the Chinese tat and install a proper image from the download section..
        Try Gemini 4.2
        • mickopla
          • 6
          Try Gemini 4.2
          Will do that, cheers guys
          • mickopla
            • 6
            Guys when using dreamup and in the middle of the flash process i get an message " Aborted by User Exciting" but i'm not touching anything. Am i doing something wrong???
            • piopat
              • 708
              that message means you will need to try a newer version of dreamup , i had a simillar problem and had to download about 4 versions before it worked . what image is currently on the box could you not factory reset the box and set it up from the start and choose english language .
              • mickopla
                • 6
                I tried a different version of Dreamup and it worked. It claimed it had erased the previous image but there are still some of the channel settings for asian satellites still there. I guess i will factory reset the box and start from scratch with the pli enigma image.
                • piopat
                  • 708
                  glad the newer dreamup worked mate ,pli or nabilosat image will be ok for that box .
