Time Server
  • Zelo
    • Mar 2010
    • 11
    Time Server
    With the change to BST my EPG clock is now wrong. I realise the easy way to correct this is probably to change settings to GMT+1 but that will annoy me. Does annyone have the address for a U.K. based time server I can enter and swap to internet time? The default server address is one in Berlin. Thanks in advance for any help.
    I am using Gemini 4.6 on a DBox 500s
  • wilf
    • 1618
    isnt there a time zone config in menu>setup>system settings>time>then set to (gmt) dublin lisbon london
    • Zelo
      • Mar 2010
      • 11
      Yes It is already set to that mate. I also did a manual 1 hour adjustemnt. So the time is correct but the EPG time is still one hour behind. I can probably solve the problem by setting the time to GMT +1 but I was wondering if there is something else I can do as unfortunately I am pedantic like that.
      • Zelo
        • Mar 2010
        • 11
        Really frustrated!
        Sorry to resurrect this but I still have the wrong time on my EPG. Dreambox 500s, Gemini image. Since BST change my transponder time has been wrong. I have rebooted the box, rescanned the satelllites but no effect. I tried changing the time zone to one that is -1 hour from GMT but the transponder time stays the same. I can manually adjust the ox time, I know that, but if I do the EPG time remains wrong and it is annoying. I realise this is a minor problem but it is just irritating every time I watch TV that I can not fix it. Any advise please? Also is there not a time server address I can put and use Internet time? The default one is in Berlin and when I googled UK ones none work.
        I would be very grateful if someone can tell me how to sort this problem out. Thanks in advance
        J
        • Wingnut
          • 376
          same thing happened to my mate, he was baffled and just powered of and on box and all was good
          • popi110
            • 128
            i have the same prob with gemini 4.6 what i have to do is change the time zone to - 1hour and then change it back again to GMT do not know why but it re sets it
            • Zelo
              • Mar 2010
              • 11
              Thanks alot for the replies. I have tried both methods above with no success. Driving me nuts, going to end up divorced due to this :P
              • jags53
                • Aug 2009
                im in the same boat, nothing seems to work
                • bubbles69
                  • Feb 2010
                  • 1155
                  use a different image perhaps?
                  • Adam_UK
                    • 464
                    I use Darkstar 2 and never had such a problem.
