Hi,
I have a dm500s running pli jade and had it on 28.2 and all worked well. I purchased a Technomate Diseqc H-H motor TM-2300 Super and setup as per manufacturers manual.
My postcode is IV125EH and the co-ordinates are as follows
Latitude: 57? 34' 60" N
Longitude: 3? 52' 0" W
Magnetic declination: 4? 21' WEST
Declination is NEGATIVE
Are these settings correct for my area?
In the motor config section which is driving me nuts as they dont seem work properly, I have the following modes.
Drive to 0" (i take it this moves the motor back to 0 degrees but doesnt seem to do a thing.
Position (This allows me to manually move the dish location and works fine)
Drive To Stored Position (Drives to manually stored position (28.2) but when it moves to 28.2 it wont move back to position 0 if i choose the Drive To 0" option?)
Drive To Satellite (Should this move to the pre-stored sat list of the satellite.xml file?
Recalculate (No idea what this does)
Set East Limit (Limits motor from going behond set point)
Set West Limit (Limits motor from going behond set point)
Disable Limits (Disables limit features)
I have also heard "USALS" Universal Satellites Automatic Location System mentioned for dish setup but i cant seem to find this anywhere within the pli jade image?
Which is the best method for setting the above?
Im thinking if i set my dish from default motor setting 0 degrees to 0.8 (thor) and use the manual button on the motor then look for the best signal for thor from that point then store and scan transponder i should have thor stored with channels then move onto my next sat say (28.2)using the same procedure would this work? or am i all over the place?
Any help would be much appreciated!
) or do you think the 90cm dish will help?
