hi,please help.on my dm500sdvb (silver & black),the image is nabilosat v0.8 blue.when i go into the addons manager to download cccam.it comes up connection to server refused.check your network settings.i dont know what to check in the settings.if manually done can i ftp it via dcc and if so, which folder do i load it to. ect,tmp or var.also which files from the cccam 2.1.3 folder needs to be loaded.thanks in advance
dm500s connection to server refused
Depending on what image you have installed do Menu> Setup > Network and check you have the gateway and nameserver configured in yor settings.hi,please help.on my dm500sdvb (silver & black),the image is nabilosat v0.8 blue.when i go into the addons manager to download cccam.it comes up connection to server refused.check your network settings.i dont know what to check in the settings.if manually done can i ftp it via dcc and if so, which folder do i load it to. ect,tmp or var.also which files from the cccam 2.1.3 folder needs to be loaded.thanks in advanceComment
