Dreambox DM500-S not shwing on tv?
  • Lotus786
    • Apr 2010
    • 12
    i have had my drembox for 5-6 months now and my dream dm500-s is not showing nothing on my tv for some reason can any one help me plzzzzzzzzzzzzzzzzzzzz
  • father ted
    • Feb 2008
    • 1389
    you need to give more info
    are you cs?
    what differnece have you done that you didnt do b4?
    if it was wroking whats changed?
    • Lotus786
      • Apr 2010
      • 12
      well i changed the ip adress and click on install updtaed off the interent by acciedent and after that the screen went black.
      • father ted
        • Feb 2008
        • 1389
        what youve done is removed your .cfg file and everything you had on it b4 you updated you need to download cccam you had b4 also the .cfg file also you lost all your bouquets and service files becasue you updated it ,did you by anychance keep a copy of everything you had??
          Be more specific. Are you card sharing ? Installed what. Start from the begining and explain what happened
          • Lotus786
            • Apr 2010
            • 12
            NO i never made a back up of a image
            why is it important to
            • Lotus786
              • Apr 2010
              • 12
              BullD0g okk in detail
              i accendential changed the DBox ip adreess and clicked on updated through interent after i click on that all i saw was a black screen is that ennough help
                As i said, are you card sharing ? Change the ip back to what it was. check your cccam.config make sure its right.
                • Lotus786
                  • Apr 2010
                  • 12
                  i am not card sharing i am steaimin of the interenet i cant change the ip adrees as i can see nothing on the tv
                    you need to go through the menu and find communications setup and change the ip there. However i think your problem is not the ip address which may be assigned by DHCP rather, your cccam config file needs updating.
                    • Lotus786
                      • Apr 2010
                      • 12
                      i took it back to my friend he will flash the image agian for me and it should work now
