Config doesn't work with diseqc switch
  • chapdis
    • 16
    Hi all,
    I have a DM500. 1 dish, 3 LNB (HB13, Astra 19.2, Astra2 28.2) with a diseqc switch 4 in 1.
    I am trying to get the right setup in the setting but cannot achieve it.
    I put LNB0 for Hb13, LNB1 for astra 19, LNB2 for Astra 28. Diseqc 1.0
    Diseqc 1 for HB13, Diseqc2 for Astra19, diseqc3 for Astra28.... I can only achieve to lock HB.
    Strange..... Any help ?
    DM-500-s / Golden Interstar GI T/S 84 CI PVRX
    Lat 43.6 North - long 3.88 East
  • chapdis
    • 16
    any luck ?
    • krazylegz
      • 2834
      are you sure it is alligned properly m8?? the slightest bit out will be well out as the lnbs get further away from the first one
      PS3= krazylegz120282
      • chapdis
        • 16
        Yes, well alligned. It worked great with my Golden Interstar.
        • chapdis
          • 16
          I have checked my LNB > Okay
          The dideqc switch, okay
          Allignement, okay
          Setting,
          Using LNB0 for HB, LNB1 for Astra 19, LNB2 for Astra2
          LOF/H 10750, LOF/L 09750, threshold 11700
          Diseqc 1.0
          AA for LNB0
          AB for LNB1
          BA for LNB2
          Hbird locked ok
          Astra 19, lock on some transpodeur
          Astra 29, cannot lock
          Thanks for your help
          • chapdis
            • 16
            No further advices ???
            I might think the tunner of my clone is a poor built. Dish might be a bit short to get astra2 (80cm - Lat 43.6 North - long 3.88 East).
            Any help appreciated
            • hackenz
              • Oct 2008
              • 36
              I've read on another forum that some LNB's "lock" if you can turn the box off & this resolves the problem then the most likely cause is your choice of LNB or switch.
              Text from another Forum.
              "I had similar problems with my DB7020 with various disecq switches a while back. I cant give you an exact explanation, but it seemed one particular lnb "trapped" the switch and refused to let go of it. Therefore when you switched satellites I got the dreaded "no signal" The only way around it for me at the time was to switch off and restart the box, setting the startup channel onto one of the unaffected lnb's. The switch wasnt at fault - an lnb swap sorted it out for me..
              It might be worth swapping the lnb's around to see if you have a similar problem.
              Ive seen this odd behaviour with a couple of lnb's (different manufacturers) now so its not unique, but Ive never been able to find a reason why it was happening."
              Hope this helps
              3 x 500s - 60cm Dish with Lemon 0.2 Quad on 28.2e - 1.1M Triax Triple Lnb on 13/16/19E - All Networked.
              Monkeykicker On BST
              • chapdis
                • 16
                Thanks m8. Got arround every step. Think my dish might be undersized to get astra28 (i got it with my Golden interstar though). Think the poor quality built tunner of my clone is to blame.
                • hackenz
                  • Oct 2008
                  • 36
                  Yeah an 80cm dish for your region of France might be pushing it, why dont you update your satellites xml here
                  http://satellites-xml.eu/
                  Hackenz
                  Monkeykicker On BST
