so much info
  • swf3
    • Mar 2009
    • 73
    so much info
    i got a dreambox 500s on its way
    i would like to know what the best/cheapest way to up date it, install , via my laptop what cable will i need there so many out there, would this do the job? USB to RS232 Serial Null Modem Cable COM DB 9 Pin Lead - USB and will i need any thing outher?
    thanks for any info guys xxx I only have usb on my laptop
    can it be done via NETWORK LAN PATCH CABLE LEAD?
    thanks mod for moving it, good work once again!
  • swf3
    • Mar 2009
    • 73
    anyone help please
        What i will add is if your laptop doesn't have an rs32 connection i would use a pc if you have one.Some people manage to flash using a nullmodem with a usb connection on the other end. I could never flash it successfully using a laptop, and i tried two different boxes and three different laptops
        • swf3
          • Mar 2009
          • 73
          thanks mate i have that as a fav very good info
          its just not knowing if this is the rite/best cable to buy as i have only usb on my laptops
            As i said m8 it's a bit hit and miss. Some people manage using that lead others like me fail
            • swf3
              • Mar 2009
              • 73
              thanks mate we was posting at the same time, i have no pc so i will have to try this, i will let you know ho it goes
                ok m8 good luck
