DM 500HD firmware update via browser
What you need to update the firmware:
You need a current image. Such an image for the DM 500HD has the extension *. NFI.
It is not possible einzuspielen another image type such as *. IMG!
Do not try it please, it does not work.
You still need a DHCP server on your network, an intact bootloader
You need a browser and a network cable. Connect your Dreambox to your
Switch / hub / router.
To import a new image to the Dreambox, you must have the "2nd stage" Loader
in place and undamaged.
The next steps refer to a network with a DHCP server running.
- Turn off the dreambox, use this switch back in the pits. The
Standby is not enough!
* (1.) Press the button on the front panel and hold it down.
* (2.) Turn on the Dreambox via the switch on the back of housing a
* (3.) your Dreambox now get the next free DHCP IP address from your router.
- Now, open a browser on your PC.
(1.) Enter the IP address in the address field of the browser "http://ip/" field.
- (2.) Now press the pick "firmware upgrade" of the displayed page in
Browser.
- On the next page, you can now select the desired image you
dubbing in the box like. Please note the file extension *. nfi that
dub
other images is not possible (NO *. img)!
- Click on the selection of the images on the selection of "FLASH!" and wait
please
completely transferred to the image was flashed.
- Turn up the whole box, and then ask then on again.
The new operating software should now be recorded and boot
Browser.
dub
please
