i have got my dm600 working how i want it and now i want to take a back up image with dreamup but when i connect it to box with null modem cable and switch on it says box is networked in http mode .......anyone know what that means? i dont want to change anything in case i loose all my settings.
back up image
Try one of these plugins;Comment
no need be sorry mate, you were spot on i saved my image from within, i thought it was like my 500 where i use dreamup to save.
thanks very much, ill give them a go, now i know what im doing.Comment
Read the RED stickies in the cable section
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'.Comment
Yes I saw that. However, that guide seems to only work with .img files and the backup script above creates a .nfi file.
Don't know if is as simple as renaming but it's been some time since I played around with the box so I am not sure...
Thanks,
JLast edited by willeewonka; 9 November, 2010, 16:10.Comment
The dm500 use the .img image file and if you have a dm600 you need the .nfi. Check post #3 for the relevant plugin.Comment
