DM500 FTP Component not Ready
  • Alexandros04
    • 5
    Hello everybody I have a problem with my dreambox dm500, I have gemini 4 on it, i try to install cccam on it manual (beacause blue panel doesn't work hangs on 21%) I connect via DCC it says telnet connected ftp connected but when i try to send the cccam package it says FTP component not ready, one thing i noticed is that the whole ftp system is not as quick as it should and i can't use the web interface. I tried to flash it with Pli Jade2 with cccam via Flashwizard Pro 4 but after connected it hangs on 0% when it says sending. I will try flashing via dreamup as soon as possible but i haven't got the right cable now
    Thanks in advance
  • westkill
    • 2378
    reboot the box and restart dcc programe
    or
    try a different ftp see if that works
    or your image maybe corupt ,may have to reflash
    • Alexandros04
      • 5
      the problem is i can't flash it via flash wizard pro, i have to use a null modem cabel but i can't at this moment.
      I now connected the dreambox via crossover, it connects ok but when i try to send a file it connects and disconnects some times and at the end it will not copy the file for the full 100% to dreambox
      • nads786
        • 9
        why can you not use flashwizard pro, you must be doing something wrong or is there another problem, best thing to do it,
        factory reset it, then flash it using flashwizard pro, setting have to be correct for letting flashwizard to work, then install cccam plugin as usual from the gemini plugin menu, and then try using dcc using correct ip, hope this helps,
        flashwizard might not be working if your setting inputs are incorrect, like the ip, username, password. the default username and pass is
        username"root" password"dreambox", ethernet cable, is the ethernet cable connected to the box directly, or router, there maybe an IP conflict in your network restricting your dreambox connecting to the internet. check if your dreambox is connected to the internet, if your using gemini, go to addons and gemini server, if an error comes up then your not connected to the internet, if no error message comes then your connected. thats all i can say
        • Alexandros04
          • 5
          ? got it working via ethernet crossover but still not able to flash it, ftp ain't working right
          • nads786
            • 9
            Why cant you use a null modem cable? have you not got the port in your pc?
            • Alexandros04
              • 5
              I have the port but not the right, the dreambox has male my pc has male and my cable is female male, but i will bring it to a friend to flash it.
