DM500 clone envision hangs
  • cannon_29
    • 5
    i have a dm500 clone (envision).the problem i am facing is that my box hangs after a couple of minutes after boot,whatever channel i am watching keeps working,but my box does not respond,its like it is hung.Help.
  • iKay
    • Apr 2010
    • 182
    which image r u using? and what is the dish setup u have?
    i used to get this on Gemini images and 3 LNB dish.. but very rare though
    one more reason is overheating.. the clones have overheating issues
    • cannon_29
      • 5
      J-tag
      I am using EDG image,but this started when i was using a pli image i have tried many images but in vain still have the same problem,i have j-tagged my box,and flasged an EDG image but i am still having the same problem.the ibm settop chip gets heated up and the box hangs.if i keep the box on for some time when it hangs the box will not boot sometimes its just the green led that comes on and somtimes its no led on.then i have to j-tag the box to get it to come on again,could it be a hardware problem?
      • maarten57
        i also had a lot of problems with new images on my DM500.
        Maybe you can do it with this version of dreamup its without networkconnection so you need a 0 modemcable.
        http://www.pli-images.org/forum/viewthread.php?forum_id=32&thread_id=11681&pid=122 378#post_122378
        With this you can load the latest PLI images.
        All my problems were solved after i did it this way.
