HELPPPPPPPPPPPPPP
  • under007
    • 14
    HELPPPPPPPPPPPPPP
    HELPP!!!!!
    I am a dummy in DMbox i have just installed a image on my DM 500.
    the DK 1.1 !!! but i cant reach my dmbox via ftp anymore and on my tv screen i get digital-kaos logo thats what now!!!!!!!!!!! :.(
    First thing you need to do is go into network settings and change the ip address so you can connect to your box
    • under007
      • 14
      i have a router the ip is dynamic...do i have to resset the router so that the box get a new ip???
      • father ted
        • Feb 2008
        • 1389
        no go into the box and set it to dhcp m8
        • under007
          • 14
          i dont know how?
          This is a reamde file this file was with the image!
          here is a backup of my working dk1.1 image
          to flash use dreamup when it says flash erase choose nien
          ip is set to 192.168.0.5
          it has the latest rom fixes.latest pic icons and i have put dreambox editor on it in the plugins for manually putting keys in.
          i find to manually put keys in you have to press the buttons hard or they do not appear on screen.but this auto updates at the mo anyway.
          just helpful if anything changes in the future.
          channel scanning
          press menu
          then go to setup
          then go to service searching there is adrop down menu to choose your area.
          this is not set to widescreen you can change this by going to menu, setup,av settings and change to 16;9
          once channels have been scanned go to bbc1 then go to slysports press and hold info button it will show evocamd on screen press ok it will restart
          emu then wait and channels should clear
          to enable picicons press yellow,choose kaos extra settings,go to picicon disabled press rght until "/var/etc/picon" then exit menu press and hold standy
          select reboot now
          to edit channels i use dreambox edit you can also make your own bouquets with that software
          hope this helps a few people and finally thanks to
          dk team for the image
          Jasmeet_87 for the pic icons
          Cydine, Wiggy9906 and xxxmkxxx for the rom fixes
          not sure who made dreambox editor plugin
          • under007
            • 14
            no one who can offer me help!!!!!!!!!!!!!!!
