help for first time use open media 500cs
  • marseille
    • Aug 2008
    • 80
    i tried all night to setup my box what i flash kaos v1 image was succes and i was follow the instruction iwhen i reach lan configuration ok but not disquest seting for sat what do ? i am confused .after flash image do i need akeys how to do it?
    pls can you advice all step by step for setup this box to work
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    To watch any satellite package, you will need keys.
    Whether those keys are obtained by purchasing a card from the provider or using an emu like evocamd and entering the keys manually into the softcam.key file (/var/keys).
    Depend what satellite your dish is pointing to and depends what package you are trying to watch.
    If motorised select complex diseqc configuration if not select none, put in long/lat setings if motorised, select what satellites to scan or load channel settings using dreamset or dreamboxedit, connect to internet and ftp over keys to var/keys, using addon server on image download cam and config.
    • Curious123
      • 2591
      I didn't get round to trying the DK image for sat when I had my dm500S and now that I have sold it for a dm600 I am not going to be able to try it on my box. If you have managed to follow DF advice and still can't get your box to work than may I suggest with apologies to DF for recommending an alternative image that you flash it with the Nabilosat V.8 maxvar image purely because their download server has all the files that you require for getting your box working. Flash the box with nabilosat follow DF advice and than with your remote press the Yellow button and download the Captains settings, nabilosat key, and CCCam 2.0.9. All of these will be installed automatically for you once you have downloaded the files.
      • marseille
        • Aug 2008
        • 80
        hi curious how can dowload a captains settings ,nabilosat key,and cccam 2.0.9
        pls
        • father ted
          • Feb 2008
          • 1389
          pls
          it can be done a couple of ways
          1 you can download them to your desktop and manualy install them
          2 you can go to their site connect your box to their network and download them
          • aftermath
            • 4345
            pls
            you will need to get your box to connect to your network, wether it be direct cable connection to PC or through a wireless connection through your router.
            You will need to change the IP on your box so your network can be able to ping it.
            its in settings, advanced settings .
            Once you get connected, you do as Curious says, press the yellow button and install the extras from there.
            • marseille
              • Aug 2008
              • 80
              i did every thing but my problem is how to flash a emu or keys
              • Curious123
                • 2591
                The reason I recommended the Nabilosat image was because you could download all the cams, emu keys and settings from their download server. All you really need to do once you have flashed the image is make sure you have got your dreambox connected to the internet.
                • buzzbomb
                  • 106
                  Guys have downloaded and installed ccam209 and nabiastkeys_nab updated 26.10.08 from the nabilo server. Could not find the Captains channel list anywhere can u tell me if it is on the server ??
                  VU Solo2 (clone) , Alsat GBOX V3000 positioner, 1.8m Precision motorised dish. Invacom twin 0.3 LNB, Image Blackhole 209 clone safe. Quad core Android TV box running XBMC and many other Appsl
                  • Curious123
                    • 2591
                    Checkout their download manager it is usually listed with settings or the yellow button.
                    • aftermath
                      • 4345
                      its either the blue or yellow button on remote
                      look for addons, and then download them.
                      you will have to be connected to your network so you can download them.
                      I do know that PLi images have this option, but cant remember if Nabilosat images have this option.
                      you could check on the nabilosat website.
                      • buzzbomb
                        • 106
                        Guys another piece of info please. What packages on Astra 19e and Hotbirdshould now be open with ccam209 complete and nabiastkeys files loaded ? (I assume u have to do a reboot to activate the changes?)
                        • Curious123
                          • 2591
                          If you can't download the Captain settings from Nabilo than you can download from here thanks to thered and install with program dreamboxedit.
                          • buzzbomb
                            • 106
                            Thanks again guys for ur help. Didn't know about the blue button to active the ccam . Polsat now open. 2 more questions please 1) can u give me the address for the nabilo web site 2) can u have more than one cam operating at any one time ie have ccam running just now could I load mgcamd as well?
                            • Curious123
                              • 2591
                              The site you are looking for is ::::>>Nabilosat Forum<<:::: don't have the nabilo image on any of my boxes because it won't work wit 28.2E but I think you can have more than one cam.
