DM500 in dm500 out
  • the man
    • 1660
    DM500 in dm500 out
    hi guys thats he socket (out) on the back on the dmbox for?
    need abite of info guys is it for i.e one cable in dmbox then 1 cable out to a sly box? or to a nother dmbox?
  • piopat
    • 708
    you can use it to run cable to a second box but its not ideal . you would be better advised to get a dual output lnb if you want to have 2 boxes .the problem is that 2 boxes would be sharing one lnb so either one box box would need to be switched off or both boxes would need to be viewing the same channel or the same transponder .however if the box downstairs was not being used if you put it in stanby mode the box upstairs would work fine.
