how to change record path to /home/someting/movie ?
  • mangup
    • 5
    Hello I am new in this forum.
    My friend heve problem. They buy some multimedia storige drive with 500 GB and he like to use like storage for dreambox 500S with some gemini (do not know what version). There is problem that network drive is accessebile from network in path \\192.168.0.23\c2-share\. I was mounted that path. Everiting OK. But when I want to record there is problem.
    On \c2-share folder there is just folder named "c" that is actuali local HDD with 500 GB. This is problem because I cant create movie folder on c2-share, but in c i create folder movie.
    How to change record parth from /hdd/movie (\\192.168.0.23\c2-share\movie) to valid folder /hdd/c/movie (\\192.168.0.23\c2-share\c\movie) ?
    I need tip for this.
    Thanks and sorry for my english.
  • mangup
    • 5
    anyone know how to do this ?
    • scuba
      • 198
      don`t change ur local dir,only change ur Directory where it`s recording to on ur pc.
      • mangup
        • 5
        thank scuba for answering , but I canot change that url on multimedia device.
        • scuba
          • 198
          check this thread
          • mangup
            • 5
            Originally posted by scuba
            @scuba , thanks but that is not answer or tips for me.
            Dreambox see /hdd mount and there is /hdd/c that I can't change !! inside c I have movie folder. Problem is that I cant change in multimedia device share name or name of C "folder" (virtual folder, actuali root of HDD 500GB).
            Again my, question is how to change record path from /hdd/movie to /hdd/c/movie ?
            P.S. Linux is open source , I was searched files, but not found where to change this.
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              You can't change it from /hdd/movie. Although linux is open source, once the image is compiled, the main code is no loner editable.
              You don't need to change from /hdd/move to /hdd/c/movie, this is the mount location on the dreambox. Just create a folder in the root of your 500GB drive and put that in the 'Server Directory' in the mount settings. Don't try to mount it using the remote and onscreen menus, use the web interface.
              • mangup
                • 5
                Ok I will try when go home. Thanks
                • alunfennell
                  • Oct 2008
                  • 1525
                  Use Dreambox control Center to change the path that you want its the easy way of doing it .
                  Go to tools then Expert option & change the path address.
                  **The Worlds Best Interactive F1 Strategy Game**
                  • chemmaster
                    • Apr 2011
                    thank you.. i have the same problem.. let me check it
                    • effbiai
                      • Oct 2011
                      thanks for this! will test it as soon as possible
                      • miki35
                        • Dec 2011
                        posting to receive download acces
