DM 500s and Standalone Positioner
  • buzzbomb
    • 106
    Hi guys was wondering if anyone has got their 500s working properly with a standalone 36v positioner. ie the dish is moved independant of the channel selection. I would have thought I should have used the "non standard user defined config" in the Sat Config menu but when I allocate different LNB's to each of the sat I want to store I end up losing the signal. If I leave the LNB at 0 for all the sats stored then the config reverts to "many sats via diseq rotor" and I end up with frequency problems.
    Any suggestions or comments welcomed
    VU Solo2 (clone) , Alsat GBOX V3000 positioner, 1.8m Precision motorised dish. Invacom twin 0.3 LNB, Image Blackhole 209 clone safe. Quad core Android TV box running XBMC and many other Appsl
  • Sicilian
    • 168
    I think you need to tune all the sats to the positioner first, then connect to dreambox & setup as if your using a diseqc motor.
    D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
    • buzzbomb
      • 106
      Thanks for that Sicilian. Unfortunately my positioner box is an edon 2120 which is not diseq compatible. I have all the sats stored in it but it is totally independant of the channel selection. (Ive had it for about 10 years) If I cannot find anyone with a similar setup I think I will invest in a v box.
      __________________
