i know the dish is lined up properly by my other reicever i tryed 4 different images the box is a clone using image at the moment Nabilo Darkstar thanks
500 will not lock onto signal help needed
Sat lock
Have you selected " one single sat " . I'm on 28.2e also,had same problem before, by selecting this option I got sorted right away.sigpicComment
500 will not lock signal
if the less the signal lock you have tow option to repairing . one resistance inside the green in picture make jambing wire very small and think wire after starting the box and wait some minute . its working a second option if not working need to fix one diode size 407 its jambing also near the capistor .
baraja & Digital KaosComment
Do This Jumbing
100% working after repooting the box
I have same problem with this box, I have not been able to get it working. Very rarely it works for a few minutes then signal gone again, but most of time is simply shows no lock. I know my dishes are ok as I have recently put a new one up and it works fine with standard Sky box.
I have shorted the green resistor marked F70 but still not getting a signal. I don't understand your second option, please can you explain in more detail.
ThanksLast edited by Code Breaker; 18 September, 2010, 22:25.Comment
