Probs Flashing DB500
  • steffmak
    • 15
    Hi guys just got dream 500s, came with no image. Tried to flash enigma using null mode cable and dreamup v1.3.3.6. Got connected to box loaded in flash process started, but then got error message saying (aborted buy user exiting)
    Followed instructions from forum. Any advice appreciated
    As far as i can see the box has came blank ? im using bitdefender firewall
    Steff
    It could be the version of dreamup your using, try a different version. There are images in the downloads section, Nabilosat and Pli jade are two good ones to try
    • steffmak
      • 15
      Probs flashing db500
      Okay thanks will give a try
      Steff
      • Hedis
        • Feb 2010
        • 4
        Also make sure you don't have any application running that is scanning the computers com-ports. (like Sony Ericsson sync software for mobile phones) They make a big mess in the background.
        I would recommend PLI image. Works like a charm on my DM 500T.
        • redout
          • Mar 2010
          • 139
          1.2.2.0 done the trick for me if that helps.
          Needed to try 5 different versions of DreamUP before it worked.
          Londres 1992 - Par?s 2006 - Roma 2009 - Londres 2011
          • andy91
            • 3583
            I had similar problem with my Dm 500 and found Dreamup 1.3.3.4 worked but not all images but Pli Jade 3 maxvar is a user friendly image for the Dm 500 if that helps.
            Andy.
