Low signal strength on Sky sports1 +few others
  • chartman
    • 6
    Using a D500S clone...
    Most of my channels are ok, with AGC around 92% and SNR at 82%, BER negligible.. SP1 (+a few others) have 85% and 73/74% and BER up at 15,000 - 20,000. Basically unwatchable..
    I'm in the south with a 45cm dish and quad lnb. The smallest adjustment to the dish results in the signal unlocking.... so Iknow it's aligned spot on. TRied rotating the LNB as well...
    Sky sports 2 is 95% and 85%, BER 0.
    Would marginal trees cause this type of problem? (I've swapped the LNB and same results.)
    I'm thinking the solution will be a 60 cm dish with a 0.1 LNB
    TIA
  • dandanthegardeningman
    • Mar 2010
    • 65
    hi mate just idea before buying another dish .if any one else you know as same sort of box take it to there house try it there vice versa/to help solve the problem if the got same dish up .then your looking at the trees for problem .dan
    • chartman
      • 6
      Thx, done that already. My son has a 45cm dish and it's all 100% there... Ordered a 60 cm dish. I'll report back with the results at the weekend.
      • romprod
        • Oct 2008
        Have you tried an inline amp from Ebay for about ?5? If not than you should deffo try one before upgrading anything else.
        • chartman
          • 6
          TRied the inline amp, no difference, which is not surprising as both the signal and noise are getting amplified.OK so the noise bandwidth will be attenuated a little, but the overall SNR won't change by much.
          Up on the roof to fit a 60 cm dish and 0.2 LNB today...
