Help For a Newbie, Thanks In Advance
  • danishcj
    • Mar 2010
    • 15
    hi
    i have bought a dreambox 500s, and i have flashed it using dreamup the new image is Gemini 4.7.0. after installed the image i did go to blue panel-addons and downloaded ccam2.1.4 and installed it(if i did this last thing, this mean that i have no problem with connections) and then also selected the ccam instead of "common interface" after all this there isnt any channel that work only the fta channels work. then now what i need to do?! i read on several posts about changing the ccam.cfg file by using DCC and di go there but i do knot know what i need to type? i am really confused (ps i hope i explain clearly what is my problem) so please could please explain me what is the next step to do? thanks to everyone in advand
  • firestorm
    • 1550
    you have done every thing right so far but Cccam will not open any channels with out card sharing and the subject is banned on this site.
    ps there may be a few channel left open by using keys you can down load them the same way as you downloaded your Cccam2.14 via the server
