500s tuner dead?
  • the man
    • 1660
    500s tuner dead?
    weird one , was testing a new 500s after a few hours the tuner seam to of died, I'm getting Sr 65% when i unplug the sky feed i get 65% Sr, iv tested it on 3 different feeds all the same, i tested a old 500s on the feeds and was fine
    is there any thing i can do to fix the tuner?
  • styla
    • 223
    well tuners are cheap anyways for a dm 500s u can simply replace it for a new one other then that i am not too sure
    • the man
      • 1660
      are they easy to swap over?
      • stone_db
        • 8
        Yes, it's easy, you have to remove the old tuner from the slot and put the new one in place. The tuner ALPS costs more or less 50?...
        Good luck dude !
        • alunsoooh
          • Jul 2010
          • 7
          hi.
          all dreambox 500s in market its chaina . you think the problem in tuner .
          20% in tuner damage
          40% in resistance short
          40% in diod not workink
          first need to try to repair resistance (( very easy make jumbing in resistance. then try is working.
          if not working go to next step:
          second need to fixed one diod (4007) if not working
          100% need to change tuner .........
          req...
          alunso
          baraja & Digital Kaos
          • the man
            • 1660
            its fine last nite for a houre then went again, today new image its up and running now for 90 mins
            can a bad flash or image do this type of thing?
