hi there just installed my satelight set it to roughly south choose thor but wont lock on can anyone help please used a sat finder and get good readout from it cheers
dont lock on a satelight
Make sure the pole is plumb all around, send the dish to BBC world news on Thor and move the dish around until you pick it up.
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
Assuming your dish and motor are set up correctly, Set the motor to zero, get a compass and poiint the dish due south . Loosen off the dish and motor and send the dish to Thor 1W BBC world news. If you haven't got a sat finder then Swivel the dish around the pole and move it up and down until you get something. This isn't as easy as it sounds
but yu will get there in the end.
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'.Comment
Have you done what i said ? It's not locking because it needs to be tweaked to find the satellite. Have you had it working before ? what is your snr
Have you set your lat and long correctly ? Do you pick up any other sats
You can find your lat and long settings by putting your postcode in, in multimap. Also have a quick look here m8 http://www.digital-kaos.co.uk/forums...81/#post216878
seems ok but you should really be seeing a pic. Check your lat and long are correct, though you may need to get up the ladder and move the dish a bit.
Where are you living m8. 7W is Nilesat and you wont pick anything up in the uk unless you got about a 4m dish
