i think i maybe of solved my probs can any1 advise?
  • mario123
    • 383
    ok after having a lot of probs trying to get my dm500 to drive my motor. i tryed usauls but wouldnt work so then i moved on to diseqc 1.2 so i thought i just needed untick goto x and store the postions into numbered postions then that wud move the motor to that postion but it didnt.
    but then i cam across this on the net
  • mario123
    • 383
    DreamBox Motor Setup
    Our dreambox broke, got fixed and reset.
    Now, I am trying to set up the satellites and channels again.
    I've got Astra (19.2E) working. Now I am trying to add Eutelsat W2 (16.0E). And it doesn't seem to work and I can't figure out why. Can anybody please help?
    I've set the Satellite configuration to
    'many satellites via DiSEqC Rotor' and got both satellites added.
    On the motor config, I am trying to use the gotoXX function as I can't figure out how the other option works.
    However, when checking our longitude and latitude on the internet, we have a negative longitude and my remore control doesn't seem to have a '-'. Is the '-/+' impied by setting West or East?
    As previously mentioned, I can scan sucessfully Astra transponders and add the channels. It doesn't work for Eutelsat. What am I doing wrong?
    Thanks.
    • mario123
      • 383
      Thanks.
      What's your motor? gotoXX doesn't work on some motors e.g. Moteck Sg2100
      - Yes but see above.
      I use the POSITION mode and use the < > to manually move my dish until I get a lock on the chosen satellite, store the position and then scan it.
      • mario123
        • 383
        Thank you very much. That helped a lot and it's now working
