cant put keys on
  • dk002
    • Aug 2009
    • 52
    cant put keys on
    lads need help cant put keys on box wont connect to filezilla
    or flash fxp
  • firestorm
    • 1550
    you can download them from your image server the same way you download cams
    • dk002
      • Aug 2009
      • 52
      i need more detail mate im not way up with this stuff thanks
      • firestorm
        • 1550
        dependent on the image you are using ie if you are using nabilosat image on your dreambox press the green button then a screen will appear,then press the yellow button and you will see download option just look for keys and follow the prompts to download the keys.The color of the buttons are different for different images but its the same idea
        • dk002
          • Aug 2009
          • 52
          im using the dk 1.1
          • firestorm
            • 1550
            not sure if the dk image has a server but you can do it manually by using a program called DCC
            you can ftp to your dreambox
            user : root
            password : dreambox
            change dir to /var/keys and upload your file.
            • dk002
              • Aug 2009
              • 52
              it wont ftp to the box so i am changeing image to nabilosat darkstar 2 to see if i can do it that way what do you think
              • firestorm
                • 1550
                its a good image i only use darkstar easy to use
