First don't use the USB Adaptor.
Are you doing it like this::??
Null modem cable needed, (are you sure its a Null modem cable, have you had success before with it before?) should be wired 2 to 3, 3 to 2, 5 to 5. hook it up between a pc's 9 pin com port and the box you are flashing, make sure com port 1 is allocated in Device manager, start software, select com port 1, and untick 'Use Network', click connect, plug power into box, should say box is alive and talking to us. select flash and away you go.
jbvid
jbvid
