connect dm500 to wireless
  • yamar1
    • 970
    is it possible to connect a dm500 to the web with a wireless dongle and a ethernet to usb adaptor???
    Faster than Faster
  • dave-h
    • Apr 2010
    • 659
    Have a read of,
    • alunfennell
      • Oct 2008
      • 1525
      Originally posted by dave-h
      First off dave-h a Dreambox 500 does not have a USB port so its a bit hard to plug a Dongle into it !
      yamar1 You will need a WiFi Bridge, WiFi Router Dreambox
      Features:
      1. The new addition of a USB wire is to connect a computer (desktop, laptop)for power, no need extra power adapter.
      2. It can be used for any wireless network products, such as wireless router, IP camera, azbox, eagle, dreambox, network printer, etc. Make all network products with ethernet wireless.
      3. Support any VoIP atas and VoIP phones;
      4. Support WiFi model: Ap client;
      5. IEEE 802.11b/g compliant;
      6. Support wep (64 bit), wep (128 bit), wpa, wpa2 security access;
      7. Support ssid broadcast.
      8. Frequency: 2.4GHz
      It will set you back around ?29.00 or €33.00
      Google ( WiFi Bridge, WiFi Router Dreambox) There are plenty of places to buy one from
      **The Worlds Best Interactive F1 Strategy Game**
      • rutters
        • 58
        How does it get it's power? Do you need an extra power lead?
        • zorgman
          • 45
          i use one of these made by vonet, you set them up with laptop or whatever for password and network etc then plug into the dm net port the power lead plugs into the bridge then into the dm and it works perfect. not as sensitive as a laptop wireless link about the same as a usb dongle.
          would highly recomend
          • rutters
            • 58
            Thanks for replying.
            Could you just clarify the power issue please.
            The one I'm looking at has an ethernet connection (which goes in the Dm500) but the other lead is a usb (of which there isn't one in a 500)
            Does the Dreambox,s power supply go into the wifi bridge? If so how does the Dm receive power?
            • Grizz
              • 1598
              plug the psu of the dreambox into device and device into dreambox. if you look at alunfennells pic, you can see the power lead on device.
              • rutters
                • 58
                Gotcha
                My model only has 2 leads.one ethernet and one usb however the usb connection can be removed to reveal a power connector which I presume goes into the DM500.
                cheers
                • halim2731
                  • 9
                  Home plugin is much better to use .
