dreambox motor not moving to sats...
  • chavslav
    • Aug 2010
    • 99
    just switched on, dm500 clone, just says please wait moving to 19.2 east, dish is not moving as i can see it through window, any thoughts, all cables are connected as its only 6ft off floor,(for easy access, thanks chav
    1 metre dish,tm 5400ci super,tm 1500ci super,dreambox500s(currently a harsh learning curve)..
    Have you double checked the fconnectors, sometimes they can come loose but appear sound. If all's ok with all conectors check the motor, is there a light on can you move it with the buttons. If these are all ok you could try flashing a new image
    • cgscott
      • 3513
      Go into motor setup and try manually move it. See if it works then?
      Did it work before?
      Patience is a virtue.
      • chavslav
        • Aug 2010
        • 99
        unplugging aerial from tm5400 into dreambox, and the copper wire came out too long for dm, loose connection, thanks for relies all sorted, now i can't get tring or sky italia on 13 and 16 east, but tm5400 scans em in, i've even entered tp manually but no luck...
        any thoughts, thanks
        • bubbles69
          • Feb 2010
          • 1150
          Dm500 clones have very bad problems with motors they are hit and miss, if you use rotor dm518s is much better
          • chavslav
            • Aug 2010
            • 99
            blimey definitely hit an miss, the chinese clone drives to 10 east for 16, doesn't move for hoybird, decides to go to 26,39,1 west and 19 east ok, just not interested in 13,16 and 10, any thoughts, doesn't seem to scan all tps on some sats either,
            thanks for any help...
